ok... i have this new setup w/ a soltek rv75 2 and xp 1900+, yada yada... i know the alpha doesnt fit in there wihout mod so i modded the corner off so that it would fit around the corner... the problem is this...
i first set up my system using my old vantec cooler (i forgot which model... the aluminum one w/ buncha fins)... it runs ok at like 44 c average load... so i fit the alpha on.. using all the plastic washers to ensure no screw/mboard shorts and after setting up the rig... the system totally had bootup problems... it would randomly freeze during windows boot, during windows, sometimes not even post at all... it totally seems to be something wrong w/ the cooler setup...
i dont know whatsup... any suggestions?
is it possibly i havent screwed it on tight enough to make a hard enough contact w/ the cpu?
