ive had the alpha pal8045 for awhile.. running with a sunon 80mm (39cfm). ive changed it a few times to test with other fans.. this last time though, it seems that my temps are up unusually.. i was wondering if it's possible, when switching the fan (im pretty careful when i do this btw), to misalign the heatsink (i really couldnt see the why since it's screwed in separately with it's own set of screws) to get these increased temps..
or it might just be the weather.. my indoor thermostat says 75 degrees farenheit (~ 24 C), it's been warmer outside the past few days, but even with this temp, i dont much difference in temp.
im running a athlon xp1700+ @ 148fsb = 1628Mhz.
idle temps around 40C cpu, 30C case.. in a antec sx1030, 4 panaflos (2 front, 2 back)
i wouldnt mind the temps, but after i switched back the sunon 39cfm fan, i've been locking up while running Tmpgenc (converting some stuff) ~43-44C cpu temp.. appreciate any thoughts.. i would really like to avoid removing and reinstalling the heatsink (has Arctic Silver 3 btw) since im going to have to tear the mobo out to do that.. thanks! 🙂
edit: these temps are measured thru the soyo dragon+ sensors. so im not sure how inaccurate they are..
