Alpha PAL8045 for $29.99
Maverick319
2,421
Glad I waited, as the Golden Gate dropped from $14.99 to $11.99 and the YS fan dropped a buck as well.
virtuamike
7,845
13
Wow, gorbs are cheap now, maybe I'll get one and see if I can mod it to fit onto my GF3 ti200.
thadk
43
Okay, I'm fairly new to the fan dept. How does CFM relate to RPMs, trying to get a silent/almost silent system. Which should I get with this?
SOHCC
89
Usually, the higher the CFM the louder it is. So the objective is to get the fan with the most CFM and least dBA. Anything below 35 dBA is tolerable.
Salvador
7,058
CFM does relate to RPM's. The faster the speed of the fan, the more CFM or air pressure usually. The problem is that the faster the fan spins and the more CFM it puts out, the noiser the fan is.
I didn't look at the fan selection here, but a popular fan for this cooler is the Panaflo H1. That is the high flow or high speed version and I believe that it is in the ballpark of 30 db (decibals or loudness) and puts out close to 40 cfm. This is the fan that most OC's use.
I do plan on getting this cooler for an Athlon XP. I will probably end up using a low speed quiet fan because the XP is a cooler chip and I don't plan on OC it. I'll probably use a PC Power and Cooling Silencer or a Papst. The Papst only puts out 20 cfm at 15 db's and the Silencer puts out 28 cfm at about 20 db. Both of these fans will be inaudible. I will probably just stick with the Silencer on this because I already have one and the Papst is about $20 from plycon.com.
Because the 8045 is a massive hs, you can get away with a lower cfm fan, but it all boils down to what you are planning to use the cooler for. If you are planning to OC or if you have a hotter chip like a faster Tbird, you might want more fan. Truth be told, a 30 db Panaflo will probably be silent and give you excellent cooling. There is no reason to get one of those Delta hair dryers for this HS. That's for sure.
Sal
bigrash
17,648
28
this is a good deal. I just ordered this fan from 2cooltek.com and i'm waiting for it. i paid 45 for the combo with the fan
J3anyus
2,774
I got in on this deal when SVC had it last time. It takes a little while to install the heatsink, but once you get it on, you'll never go back. Awesome heatsink at a great price.
Overclocker1
73
What fan are people getting? I want performance, but I also want to sleep at night in the same room. Should I get one of the fans that SVC has or look else ware?
Overclocker1
DEFIANT1
780
A review:
I'm not a fan of SVC's shipping. I bought on the last deal @ $32, and was told (lied to) on two seperate days that my order had shipped. It hadn't shipped, and in fact didn't ship till almost a week after first being told that it had gone out.
That being said, the product itself is fantastic.
I'm currently running an 1800+ @ 1700mhz, WinAmp/ICQ/IE/several other programs in the background as I write this, and my temps inside a Lian-Li PC65 are: (drum roll please)
36C ambient/ 38C CPU-Loaded
Disregard the instructions to set the fan to "suck". It's much better in the "blow" position. I'm using the 48cfm YS-Tech fan, and it's extremely quiet in comparison to the 38cfm Delta that I was previously using.
Conclusion: GET THIS HSF!!! If it fits your mobo, you'll never regret it! As for getting it from SVC......Just be prepared for a wait.
Colie
63
Thanks for the tip. I just ordered one with the Ys-Tech 48.5 CFM fan. Total was $40 including shipping. Great Deal!!!
GtPrOjEcTX
10,784
<< Do most current mb's have mounting holes for this hs? ShuttleAK31A ? ECS K7S5A ? >>
Will this fit on the Shuttle AK31A? Anyone, please!
Colie
63
3 pin or 4 pin? As a general rule, go for a 4 pin on any high performance fan to avoid burnout problems on the motherboard. If you get a high rpm fan with a 3 pin adapter, you can get an adapter to change it to 4 pin.
Triggerhappy007
1,550
<< Will this fit on the Shuttle AK31A? Anyone, please! >>
I heard that it only fits if you bend a capacitor out of the way. It's too risky IMO.
mdcrab
2,105
GtPrOjEcTX,
Try this link for more info.
Link for PAL8045 & AK31
I have a AK31A which I picked up on EGay for $76 + $7 shipping. I am now thinking about getting a PAL8045 w/ YS Tech fan. If you go to Alpha's web site you can get a drawing of the fan and mounting instructions. Take the drawing which shows the location of the mounting holes and the outside of the fan and enlarge the drawing (in a copying machine) so that it's actual dimensions are 80mm x 80mm and place it on your mobo and see the interference. I made some quick estimates with a mm ruler and it is tight but I don't think it is much of an interference, will resort to rat tail file if necessary. Also I want to use the 4 point mounting rather than the spring clip method which is a little scary at times as far as fracturing the the silicon wafer. You have to mount the threaded anchors on the mobo before you mount the mobo in the case, so I prefer to do it now even though this hsf is extreme overkill for a 900mHz T'Bird. Then I can update to a 1600XP or 1800XP later w/o pulling mobo.
mdcrab
