The Delta fan uses 3.84W. If your mobo fan header is rated above that, you should have no problem. My Delta is plugged in on the mobo fan header(3pin) so that I can monitor its RPM. No problem at all with the 3pin setup.
Just check your mobo specs for the fan headers.
