I just got my Alpha right now. I'll be leaving in a little while to do some things today, but I'll be back later. I need to know how to install this HSF correctly. I'll take off my cpu, remove the ASII grease with alcohol, and I'll probably buy that goo gone stuff If needed. Anyways, the HSF came all in pieces. I have the Delta 38cfm fan, and the Alpha PAL6035 HS. I don't know how to put it together very well. How do I know if the clip is in the very middle of the HSF? I see grease on the bottom of the HS, do I remove it? Will the Alpha clip probably break off my little thing that it holds onto on the motherboard? How easy is it to install the clip? The most important part I want to know is how do I know if the clip is in the very middle of the HS so that it can go on correctly.
