- Sep 1, 2002
- 14,559
- 248
- 106
I have had an Alpha PAL 8942 for a few months now, and thought it was a pretty good cooler, but the 46 cfm fan seemed a bit too noisy after a while, so I decided to try out the stock Intel fan that came with my 2.4B. Imagine my surprise when I noticed the temps were no higher than they were with the Alpha, and things were quite a bit quieter too. I could also run at the same overclocked speed that I could with the Alpha.
The Alpha has a copper center and a 46 cfm fan on it, so I knew something was wrong. I took the retain fan back off and lapped the Alpha with 3-grades of sandpaper up to 600-grit. I cleaned off and reapplied the artic silver, and made sure the heatsink was on tight with even pressure on all sides.
Did it make any difference? Not a bit. I even reached in and felt the heatsink, and it wasn't even warm while the CPU was under load, so I tightened it down as far as I could, but that didn't seem to help.
In the past, I have used a Swiftech MC-462A that had a similar mounting scheme, and achieved great results with my Athlon XP 1800.
So, before I throw this Alpha in the garbage, does anyone have any ideas as to why this thing runs so hot?
My temps are 48 idle and 64 under load, and I think it is safe to assume my IT7 is reporting temps about 10C too high.
