Alpha help !!!
yymatt
137
Got a alpha OME cooler ac-586, use for AMD K2
Having refrigeration element
Using for my duron 700
Without OC, boot up at 46C
then goes to 27:)
there is a Silicone Compound enclosed, should I use it or not?
mechBgon
Oct 31, 1999
30,699
Yes, you should always use some type of thermal-transfer material to maximize the transfer of heat (or cold, if you like).
Tschaft
445
Im willing to be whenever you put the compound on, your temps start at like 36c then go down. When I didnt have any compound on my heatsink/fan the temps would jump so high at times.
yymatt
137
put the compound on, load at 40C and drop to 17C
but when fully load after 10 min, goes up to 60C, don't know why
