ALPHA HEATSINK FAN: sunon or sanyo????
Maverick2002
4,694
ok im overclocking my duron and my coolermaster just wont suffice any more
i went over to INFLOW DIRECT and they had a alpha with sunon fan, with the option
of upgrading to a delta or a sanyo fan for extra $$$$.
i dont want to get the delta because it says that it takes up about 4 watts of power, and that most mobos
cant handle that much juice, so ide have to get a 3-4 pin adapter, and i need a 3-pin.
now as for the sanyo, they claim that its ultra quiet.
i have a sunon and im happy with it (80mm fan), so i need to know about the quality of the sanyo fan and if its worth getting.
thx
Howard
47,982
11
<< i have a sunon and im happy with it (80mm fan), so i need to know about the quality of the sanyo fan and if its worth getting. >>
From this statement you seem to think that Sunon and Sanyo Denki are the same. Not so. Yes, Sanyo Denkis are great fans, silent.
Maverick2002
4,694
i didnt say that........i just want to know how much better sanyo is and if its worth getting....
Voland
22
Yeah, yeah, Delta fans need a lot of power blah blah.... I have KT7 and PAL6035 with the delta fan. I plugged it into the motherboard and it works fine. I don't see a need for a 3-4 pin convereter cable, they just want more money. Get the delta fan, definitely - if you plan to overclock. It's a bit loud, but you get used to it.
