Uhhh, just disregard those two "Almost halved" posts. That's one of the dangers of leaning on the return key.
Anyway, what I meant to say is that the command line version of Seti@Home is definitely faster. I was originally using the GUI running continuously in the background, and I usually took 6~7 hours to complete a WU. The CLI brought that number down to around 4 (!). Then, found out that my BIOS wasn't set to the right FSB speed for my AMD Athlon 1800+, and I brought my CPU from 1.14GHz to 1.53GHz (mechBgon helped me with this - look here). This chopped off another half hour. So, all told, I'm now at about 3.5 hours per WU and lovin' it. I tried setting the priority level of the CLI higher in Task Manager (running WinXP Pro), but this didn't really seem to affect anything.
Now I want to feed the need and get an Athlon XP 3000+, the highest my chipset supports (MUST HAVE MORE POWER!!!!!!)
Oh, if a mod reads this, please delete those two empty "Almost halved" posts.
-Grant 😀
-Grant 😀
