Allround workstation in a small case?
larsp
Hi anandtech forum!
I'm about to build a new PC for allround use. The thing is, I want to avoid the usual clumsy tower case but I still want a decent workstation:
- Low power, low noise
- Small size
- Good CPU performance (core 2 duo something)
- Good graphics performance (Radeon HD 4670), I have a 1680x1050 lcd.
- TV-tuner
- 3.5" harddrive
- CD/DVD drive
When I say good performance I probably mean lower mainstream, but you get the picture.
I'm not asking about component details but I would like to get some input about the case. Can I cram these standard components into a small compact case? How small can I get, any recommendations?
Thanks in advance,
Lars P.
Roguestar
6,045
If you get a small "mATX compatible" case, you can add an mATX motherboard and stick all the other parts you want into it. Gigabyte and Asus do mATX G31/33/35 and G41/45 intel chipset boards. These have integrated graphics but you can still add your own graphics card.
http://www.newegg.com/Store/Su...=7&name=Computer-Cases
Select either "micro ATX desktop", "micro ATX mini tower" or "micro ATX slim case", then go browse the motherboard section for a good motherboard that says "micro ATX" (such as this one: http://www.newegg.com/Product/...x?Item=N82E16813128338 )
larsp
Thanks Roguestar, Micro ATX is just the concept I knew existed but had forgotten the name of :)
Checking the stores in Denmark I'm currently considering the Antec NSK1380 case which is good value for me as it includes a 80+ rated 350 Watt powersupply.
For the CPU I'm strongly attracted to "Core 2 Duo (Wolfdale) Model E7200 (2.53GHz), EM64T, 1066FSB, 3MB Cache (LGA775), BOX " as it is powerfull enough for me and very energy effecient.
About GPU, I think that ASUS HD 4670 is the right choice for me.
So the following questions remain:
1. Say I select the E7200 and Radeon 4670, beside that I will recycle one PATA HD and a DVD burner, will the 350 Watt antec powersupply be adequate?
2. How good is the Intel in-a-box cooler I get with E7200 ?
3. The big one... What motherboard and RAM should I get?? I have no clue about developments in motherboards so I need help here. My requirements to the motherboard are simple:
* Micro-atx
* Will match E7200 and Radeon 4670 well
* Gigabit ethernet
* Decent audio
* No fan
* Good, long lasting quality
* Good value
Thanks for any inputs!
(this build will be finally replace my old trusty athlon xp 2000+ and radeon 9600 XT :D )
Roguestar
6,045
The 350W should be good, assuming it's a good quality PSU. In terms of watts, it's definitely enough.
The Intel retail cooler is good, and also good enough to sustain a mild overclock should you so wish.
Here's a motherboard that looks pretty decent:
Probably not much of an overclocker but if you can't get that exact one in Denmark, look for basically any G31/33/35/41/45 motherboard by Gigabyte or Asus at a reasonable price.
jae
1,034
www.facebook.com
Are you planning on overclocking? If not, then this is build will be okay.
Are you a gamer? If not, then you dont really need the HD4670, the Integrated Video will do fine.
Theres a sticky thread that you're suppose to read before asking for help, so people can better help you.
Misco.co.UK
138844 :: Sapphire HD4670 512Mb GDDR3 PCI-Express Grapics card (1 Kg)
In Stock
£55.31 ex VAT
£64.99 inc VAT
Q136428 :: PNY TECHNOLOGIES Memory/4GB Kit( 2 x 2GB ) Dimm PC (0.12 Kg)
In Stock
£38.29 ex VAT
£44.99 inc VAT
Q124767 :: Antec NSK 1380 Micro ATX Cube Case (2.5 Kg)
Buy now - while stock lasts
£63.04 ex VAT
£74.07 inc VAT
138309 :: Gigabyte GA-G33M-S2L socket LGA775 motherboard (0.5 Kg)
In stock at our suppliers, 1-2 days
£49.35 ex VAT
£57.99 inc VAT
138522 :: Intel Core 2 Duo E7200 Socket LGA775 processor (0.5 Kg)
In Stock
£74.89 ex VAT
£88.00 inc VAT
Subtotal £280.88 ex VAT
VAT £49.15
