- Aug 25, 2001
- 56,587
- 10,225
- 126
System is:
A8N-SLI nF4
AMD Athlon 64 3200+ S939
ATI X1300 PCI-E 128MB
2x512MB Corsair DDR-400
WD 160GB JB IDE HD
Samsung 22X IDE DVD burner
No overclocking.
System posts and runs WDDLGDIAG fine to erase HD. Have yet to install an OS and run Prime95 or 3dmark, but it seems ok.
No video card upgrades planned, otherwise obviously a PSU upgrade is needed.
But do you think this is enough for now? Rails seemed a little bit low in the BIOS monitoring, 3.3, 5, 12v, were all low. 11.7v is what the 12v was showing. But I'm thinking that all three monitoring are low, since there's nothing draining the 5v or 3.3v.
There are two 12v rails, one 10A, and one 13A.
PSU was previously in a rig, powering a P4 2.8HT overclocked to 3.2. But after six months, it got unstable, and had to remove the overclock. Same motherboard, RAM, and CPU is currently in a different case with an ENP-5150 Enhance 500W PSU overclocked back to 3.2 and stable.
Will it last six months to a year? I'm putting together some cheap parts to sell. Don't want to waste money on a "good" PSU. (Alternative PSU is $20 Xion "450W", which I put into a friend's dual-core AMD 2.3Ghz rig, which replaced this PSU. This PSU was a tiny bit heavier than the Xion.)
A8N-SLI nF4
WD 160GB JB IDE HD
No overclocking.
