Get the 8350 if you intend to OC using the stock HSF.
Get the 8320 if you intend to replaced the stock HSF with something considerably better than the stock HSF that comes with the 8350.
Why? You take in consideration that if the 8350 is better binned than the 8320, the last one would need a higher vcore to achieve the same overclock as the 8350, upping the temps in the process?
Why bother with the stock HSF at all? For ~$30 you can have a Hyper 212 EVO, and you can use it over and over again. I have the plus version and have used it for 3 different processors, great cooler and a great investment.
You can always wait until you absolutely need a new CPU, the 965BE still has at least 1 year life in it, without really showing its age, but the FX8350 would be a big improvement in pretty much everything except games.
Expect to have the same performance in games and in certain games even slower.
If you are already set on getting an FX-8350 as a drop-in replacement for your 965 @ 4.1, I would say good choice.
I have an old rig (not as old as yours, ~2 years old, although some parts like the vid card are a bit older) similar to yours, but it used to run a 1090T. Could only clock it reliably up to 3.9GHz.
Almost a month ago, was able to see an FX-8350 for very cheap, and since the board in that old rig can accept it, got the FX as a straight CPU-swap.
Even against an overclocked 1090T @ 3.9, a stock FX 8350 was no worse off in the benchmarks ...
There are some other interesting data points, but you get the idea. Overall, as the first set of results would say, it is definitely no worse than a 1090T@3.9. The power savings are also significant. Compared to the 1090T@3.9, the FX 8350 idle power consumption is ~40W less. Load power consumption is even better, at ~70W less.
Clearly, with overall performance no worse than an OC'd 1090T, but with significant idle and load power consumption, it is (mostly) a no-brainer as a cheap CPU-swap.
A good cooler is about the best investment you can make for your system, and as I already mentioned you can use it over and over again. Even if you NEVER overclock, you get near complete silence and of course the potential to overclock at some point while still maintaining low noise levels.If you are worried about price/performance, 3rd party heatsinks rarely make financial sense in terms of the OC (and performance) they deliver above and beyond that which you can get out of the stock HSF that came with your "budget" processor.
Buying a $30 HSF for a $150 CPU only makes economic sense if it adds an extra $30/$150 = 20% higher OC to the OC you were already going to get with the stock HSF that you paid for when you bought the CPU.
A Hyper 212 EVO isn't going to give you 20% higher clockspeeds above the stock HSF of an 8350, but it might give you higher clockspeeds above what you'd get from an 8320 with its stock cooler (once you subtract the $20 delta you paid for the 8320).
That's odd, I tought they were the same HSFs for all the FX line (they are still bundling top bin FX with the kuhler clone AIO?).
I was thinking for a H60 but honestly, every single air cooler/AIO watercooler seems like a terrible perf/$ compared to this one, lol.
Sage advise... currently I'm draining every last iota of life from this P4 socket 478 AGP system before upgrading. I use it daily, and unfortunately, it just won't DIE! D:
Ooph, that's got to suck. Just ditch it and pick up a cheap C2D, man! You can get an old C2D desktop for around £70 in my area- that's got to be worth it, to let you escape the old P4.
Yes...........surely amazing. Maybe they are still sleepingWow not one person recommending selling it and getting a used ivy/sandy with HT or whatever, there's usually always one peddling this option lol.
135$ for such a performance (esp. OCed to 4.7Ghz) is a stealThere isn't much point in buying a 8350 over a 8320 IMO (Unless 100-200 MHz extra is really worth it to you on your OC)
I recently got mine for $135 Used all in shipped - Look around!
