all in one case, cpu, and gpu temp monitor?
drpootums
Alright, i'm getting a thermaltake tsunami and am looking for something to monitor my temps while i'm in a game.
I would like something with a lcd screen that i could switch between case and cpu, and possible the gpu temp that i could look at during a game to check the temps and see if i had to up the fan speed at all.
thx, and i hope u know wat im talking about!
Keep in mind that the case door could be a pain in the ass, depending on which side of you the case is on....it hinges at left so if your rig is not on your left side you might be better off with a non-door case.
Just a thought.
thx for the replies. Out of the 2, which do u think is better? The first one (the flower one err...watever) looks nice, but they said the sensors can overheat.
Another question is the thermaltake Venus 12 cpu fan i was looking at has it's own fan speed controller, but would i be able to control it with this instead?
i'm quite sure i will go with the cooler master, because in one of the reviews it said the knob only stuck out about 1/4 inch, and that should definitally clear the case door!
