- Dec 9, 2001
- 5,710
- 0
- 76
I bought a 4D maglite LED from Amazon and I need to get batteries for it. Are Duracell Procells any good? Has anyone tried them?
Originally posted by: bobsmith1492
Alkaline battery = alkaline battery = alkaline battery = alkaline battery = alkaline battery
Originally posted by: laurenlex
NiMH + recharger FTW
4x1.2v = 4.8v, which is well above the Vf. Nimh batteries also have much lower internal resistance than alkaline batteries and consequently less voltage sag under load.Originally posted by: bobsmith1492
Lower voltage, won't be as bright unless it has a switcher supply which I doubt in a flashlight.Originally posted by: laurenlex
"AccuPower" Low Discharge D's - $47.94 for four.Originally posted by: Throckmorton
NiMH D cells are expensive, and so are the chargers![]()
27 times... I've had the same 2 D cells in my Mag LED 3W for a year. Of course that's because I hardly use a flashlight, and when I do it's my hand crank.
No one says that you only have to use them in that flashlight, either.Originally posted by: Throckmorton
They're ready when you need them, which hasn't been the case with NiCads and NiMH cells. NiMH cells were especially bad, losing up to 1% of their charge per day.Originally posted by: alphatarget1
I was under the impression that alkaline batteries are more reliable...
