- Feb 25, 2011
- 17,000
- 1,628
- 126
So, my housemate drives an '08 Acura TSX. Every now and then I drive it for the day (when it needs to be brought in for service, basically.) Which I did today.
Maybe I'm nuts, but it seems off.
At 60+ mph, it drifts to the left. Drift gets worse the faster you go, and requires you to steer slightly to the right while you're driving. Also, the steering is kinda... bouncing around - I quickly exited my lane, not necessarily in the direction of the drift, if I took my hands off the wheel even to switch radio stations. It was honestly kinda scary - by the time I got to work, I had the wheel in a death grip.
Also, parking lot handling sucks. Turning radius like a truck; I didn't make a single parking spot on the first try. Jesus H.
Tires are relatively new (20k miles) and rotated regularly.
Am I correct in assuming this sort of behavior is abnormal for a car like this? My 2007 Ford Focus tracks straight, at even higher speeds on the same stretches of highway, and I definitely don't think of it as a "driver's car."
(While technically illegal, 80+ mph speeds are fairly normal on the rural interstates between our home, our mechanic, and my housemate's work.)
I've had the alignment checked at our mechanic, and they said it was fine, but they're honest and frugal. So while I love them, I do suspect they have a "good enough for jazz" mindset when it comes to the persnickety stuff. Do you think it would be worth my time to take the TSX to a dealer for an alignment check? Or could it be something else like a goofed steering rack?
Looking for opinions and thoughts. Thanks for reading.
