Algebra problem
coder1
433
Ok I know how to find the real solutions but what about all solutions. I can't seem to figure out the proper steps
exmaple:
x^4=125
anyone there that can point me in the right direction?
coder1
433
I appreciate the help, but this is still college algebra and I haven't got to Logarithms yet? Is there any other way?
Heisenberg
10,621
Take both sides to the 1/3 power. 1/3 is the same as 2/6 so you can have 5i as a solution also. I think - I'm on my way out the door so that may not be completely right.
jagr10
1,995
What the hell is there to find? Can't you just put each side to the power of 1/3? It's all real to me. No need to imagine things.
VIAN
6,575
This is only one solution. There are multiple solutions only to square roots. The answer to that is 5.
coder1
433
the answers are +4, -4, +4i, -4i I am trying to understand how to get to 4i or sqr(16)*sqr(-1)
coder1
433
well unless you state the problem, nobody can help you.
the acutal problem is x^4-256=0
I originaly posted x^3-256=0, it is to the 4th power insted , sorry for confusing the hell out of everyone
Howard
47,986
11
??? x = +/- 5 in your example!
Oh, new question.
Howard
47,986
11
x^4 - 256 = 0
x^4 = 256
log x^4 = log 256
4 log x = log 256
log x = log 256 / 4
x = 10^(log 256/4)
That's one solution anyway.
eLiu
6,407
Huh?! But 4^3 is 64. The problem asks for x^3=125, so x=5. There is no imaginary part because i^3 = -i and (-i)^3 = i. Thus, if you cube i, your answer will have an i in it...which 125 clearly does not. The answer here is just x=5. This is a repeated root (in that it "occurs" 3 times).
Edit: Blarr...it said x^3=125, i swear...but now it's x^4=125. Man am I seeing things?
But for this problem...the fourth root of 125 is obviously one answer. The negative of that is another. Now for the imaginary part...let's note that i^4 = 1. So, the fourth root of 125 * i is also an answer...and since imaginary roots always come in conjugate-pairs, the negative the previous answer is also a root.
coder1
433
thanks for everyones help, sorry about putting down the incorrect exponent. it is 4 not 3.
shuan24
2,558
Dude, I'll give you a hint:
x^4 - 256 =
(x^2 - 16)*(x^2 +16) =
(x-4)*(x+4)*(x-4)*(x+4) =
(x-4)^2 * (x+4)^2 = 0
Now solve for all values of x.
:beer:
dullard
26,196
4,869
Starting problem:
x^4 = 256
Take the square root of each side:
x^2 = +- 16
Notice that both +16 and -16 work. Why? Since (+16)*(+16) = 256 and since (-16)*(-16) = 256. Now there are two separate problems:
x^2 = 16 and x^2 = -16
Lets work on the first of those two. Take the square root of both sides:
x = (16)^0.5
Thus:
x = +-4
Thus either x = 4 or x = -4 will work. Check to be sure (4)*(4)*(4)*(4) = 256 and (-4)*(-4)*(-4)*(-4) = 256. Yep got two of the answers. We know there are two more answers since the original equation was a power of x to the 4 (interesting rule, did you know that)? Lets look at the second equation we ignored above:
x^2 = -16
Take the square roots of both sides:
x = +-(-16)^0.5
Now we are dealing with imaginary numbers. Lets pull out the negative sign:
x = +- (16)^0.5*(-1)^0.5
Thus
x = +- 4 * (-1)^0.5
Now the imaginary number i is equal to (-1)^0.5. Thus
x = +4i and x = -4i.
Do the check like I did above, and you'll see those also are correct.
shuan24
2,558
now it's making sense. Ok here is the last one, I can now do the first one but this one is got me stuck
x^3=125
wtf? people's been posting the solution to that.
shuan24
2,558
nice approach dullard, I just did it in a different way. :eek:
(but by using the quadratic equation it is more versatile than having a perfect root)
jagr10
1,995
x^3=125
lol.
dullard
26,196
4,869
Trying to teach someone in college algebra how to factor is like trying to teach a rock to swim. Thus I use the brute force method in situations like this. Of course my method will be difficult to show coder1 that x^3 has three solutions that all happen to be 5. So we must take your approach on that one. Good luck on the swim lessons.
shuan24
2,558
LOL! be nice!
