Algebra II HW Help
Shadow Conception
1,539
"If a set contains N elements, what is the total number of subsets that the set has?"
Can somebody explain this to me?
I know that if a set contains elements {a, b, c}, then you end up with subsets {a}, {b}, {c}, {a, b}, {a, c}, {b, c}, {a, b, c} and {}. But how can I relate this to a variable?
OdiN
Banned
Mar 1, 2000
16,430
Just say that there are no such elements as a, b, or c on the periodic table and turn it in.
fatpat268
5,853
I don't recall ever seeing this in any of my math classes... and this includes Cal 1-3 and DiffEQ, much less Algebra II
blinky8225
564
Eh, really? I remember learning permutations in my 9th grade Algebra II class.
BigJ
21,330
2^n.
Say N = 1; you have {a}. {}. So you have 2 = 2^1 = 2
Say N = 2; you have {a}, {b}, {ab}. {}. So you have 4 = 2^2 = 4
Say N = 3; you have {a}, {b}, {c}, {ab}, {ac}. {bc}, {abc}. {}. So you have 8 = 2^3 = 8
Say N = 4; you have {a}, {b}, {c}, {d}, {ab}, {ac}, {ad}, {bc}, {bd}, {cd}, {abc}, {abd}, {acd}, {bcd}, {abcd}, {}. So you have 16 = 2^4 = 16.
If you want the exact reason why, scroll to the bottom of the page.
http://www.tutorvista.com/cont...ts/results-subsets.php
The easiest way to understand it is the following explanation I ripped from a page:
For a set of n there are 2^n subsets. This is easily proved: Any subset of the set can either contain or not contain an element; so, for a subset, there are 2 states for the first element, 2 for the second element, ?, 2 for the nth element; so, there are 2 states for the first element, 2 * 2 = 2^2 states for the first two, 2 * 2 * 2= 2^3 states for the first three, ?, 2 * 2 * 2 * ? * 2 = 2^n states for all the n elements.
rocadelpunk
5,589
{} stands for the empty set, the set that contains no elements, in case you were confused by that notation.
TuxDave
10,571
Pay attention in class!
palswim
1,049
www.palswim.net
Originally posted by: BigJ
2^n.
Or you could use induction (this is "thought induction", not strictly mathematical induction):
Say you have a set of n elements, and say that it has m possible subsets. Then, adding an element, e to the set, you will have twice as many possible subsets, since you can break down the possible subsets into subsets with e and subsets without e. Subsets without e are the same as the subsets when you only had n elements, and subsets with e are the same, except they each have element e in them. So, you have 2*m subsets. If you work backwards, starting at the empty set (1 possible subset), you see the size double each time, and thus follow the 2^n formula.
Leros
21,867
7
This is the way to go.
Think about a problem from elementary school. You have 3 pairs of pants and 4 shirts, how many outfits do you have? Clearly the answer is (3 options) x (4 options) = 12. The subset problem is the same.
You have n elements {E1, E2, E3, ... , En}
For each element you have two choices, include or not include. Similar to the pants and shirts problems you simply multiply your options together.
(2 options for E1) x (2 options for E2) x ... x (2 options for En) = 2^n
chuckywang
20,133
2^N
Each element can be in a subset, or not in a subset ... therefore two possibilities for each of the N elements, therefore 2^N.
fatpat268
5,853
Nope, I didn't even know what permutations were (well, I do now, I just read up on it)
I did pay attention. In fact, I'm a math tutor at my college, and there aren't permutations even in this college algebra book they use. Or if there was, I've been over looking it the entire time.
Leros
21,867
7
I did pay attention. In fact, I'm a math tutor at my college, and there isn't permutations even in this college algebra book they use. Or if there was, I've been over looking it the entire time.
Permutations probably weren't used much in any of the classes you used. It was probably mentioned briefly in algebra and/or calculus.
I didn't use set theory enough to remember this stuff until I took discrete math
BigJ
21,330
Same here.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
2^N
This
God, I hate "manglish," my coined phrase for the terms used for definitions and proofs. They have the same relationship to math that grammar has to English i.e. none to speak of.
Epic Fail
6,252
I am going to threadjack here.
If you have 10 pills, 6 reds and 4 blues, what is the probability you will get all 4 blue pills when you take 6 pills?
34,035
The numeral 2 is unpleasant; it looks like a twisted coat hanger. We need a better glyph to represent two.
RaistlinZ
7,470
9
It's true what they say.... you're never going to have to know this stuff post-college.
