Algebra help again!
Nocturnal
Right now I'm trying to find a solution to each system of equations by substitution.
the problem I'm having is finding which variable to solve for and then putting it back into the equation itself.
2x + 3y = 7
6x - 2y = 10
Do I need to turn these equations into the slope-intercept form like y = mx + b or can I just solve for whatever variable I feel like it in order for it to get a regular answer or real number answer?
I would first try to turn it into y = mx + b.
So, I would subtract 2x from both sides of the equation which would bring the equation to 3y = -2x + 7
Which in turn I would divide the 3y out by 3 to get "y" by itself and then I would have (I'm going to spell it out) negative 2x over 3 + 7 over 3.
Now I have what y is equal to. I plug that into the second equation or, can I plug that into the first equation and then solve for x?
HELP!
If I read all that correctly, yes, once you solve one equation in terms of the other variable (in this case, y in terms of x), you substitute the right side of that equation into the other variable in the other equation and solve. Figure out what that variable is and then go back to one of the original equations with it and use it to find the other. Use both equations to check your answer.
2x + 3y = 7
6x - 2y = 10
(-3)2x + 3y=7
+ 6x - 2y=10
y=17 (because -6x cancels 6x)
(original equation) 2x + 3y=7
2x + 3(17)=7
2x +51 = 7
2x= -44
x= -22
Does this help?
Originally posted by: kehi
2x + 3y = 7
6x - 2y = 10
(-3)2x + 3y=7
+ 6x - 2y=10
2x + 3(17)=7
2x +51 = 7
2x= -44
x= -22
Does this help?
You got the equation wrong. You need to solve it in y = mx + b.
2x + 3y = 7
6x - 2y = 10
(-3)2x + 3y=7
+ 6x - 2y=10
2x + 3(17)=7
2x +51 = 7
2x= -44
x= -22
Does this help?
For substitution yes, but otherwise that's a fine method. You can also put it in x = ay + b
What was the answer? I got x=1, y=5/3. But graphing it i got x=2 y =1 😕
NM, i mixed up x and y, i did get x=2, y=1 😎
2x + 3y = 7
6x - 2y = 10
(-3)2x + 3y=7
+ 6x - 2y=10
2x + 3(17)=7
2x +51 = 7
2x= -44
x= -22
Does this help?
the method is right but the original poster did it incorrectly 😀
Ok so I have this now 3x = 8/5x - 8/5 - 3
I combine like terms which is - 8/5 and - 3.
And then How do I get one X on one side ONLY?
Do I a) multiply both sides by the reciprical of 8/5x???
subtract 8/5 x from both sides: --> 3x - 8/5 x = -3 - 8/5
or to get rid of the fractions, multiply both sides by 5 first: --> 15x = 8x - 8 - 15
Is that 8/(5x) or (8/5)x?
Muliply everythign by 5 to get rid of fraction and rearrange for x. I got x= -23/7
nocturnal, get the first equation in either x= or y= then plug into second equation for that vairable then solve for one of the answers. Plug that answer into the first equation then you will have answers for both x and y, then check your answer. For example.
2x+3y=7
6x-2y=10
solve first equation for x:
2x=7-3y
x=7/2-3/2y
plug this into 2nd equation
6(7/2)-6(3/2y)-2y=10
21-9y-2y=10
-11y=-11
y=1
plug 1 into the first equation as the y variable
2x+3(1)=7
2x+3=7
2x=4
x=2
check your answers
2(2)+3(1)=7 4+3=7 7=7
6(2)-2(1)=10 12-2=10 10=10
Sort of hard to know exactly which equation you mean, since you didn't place any parantheses around 8/5x.
3x = (8/5)x - 8/5 - 3
5( 3x ) = 5( (8/5)x - 8/5 - 3 )
15x = 8x - 8 - 15
7x = -23
x = -23 / 7
or:
3x = 8/(5x) - 8/5 - 3
3x = 8/(5x) - 4,6
3x * 5x = 8 - (4,6 * 5x)
15x^2 = 8 - 23x
15x^2 + 23x = 8
x^2 + (23/15)x = 8/15
*insert quadratic formula here*
*edit* worked it out with fractions.
Originally posted by: Ameesh
using subsitution i get x= 2 and y = 1
me too ..
you can take one equation and isolate a variable and then plug that variable into the other equation
1. 6x-2y=10
y=3x-5
2. 2x + 3(3x-5) = 7
11x - 15 = 7
x=2 .. plug that into any original equation
or you can add the equations
(-3)(2x+3y=7) = -6x -9y = -21
-6x - 9y = -21
6x - 2y = 10
-11y = -11
y=1 .. plug it back
