I'm not quite sure what sensors I should use on MBM...anyone know? Also, I notice that in the BIOS it says my CPU AND SYSTEM temps are almost 100F :0 Now, not sure about the CPU, but I know for a fact my system temp should be around 75-80F. Anyone else having trouble? Anyone know any solutions?
Also, my case has 3 pins for the power-light, however on the board it's only 2 pins. I had to pop a pin out and move it over so I could fit the plug into the header. However, the light isn't on full brightness. Very dim, almost like not enough voltage is pumping through to the LED. I tried flipping the header, but the light goes off. Any ideas?
Thanks in advanced.
Thanks in advanced.
