I can have choices other than Albatron, it's just that I've heard such good things about them. I'm in the process of figuring out what's best for me and at the best price for me to build a new computer (it will be the first I've ever built also). I've read pretty much all of the articles about the boards, compared prices and so on. I saw the Albatron boards and how much people liked them so I figured that would be who I would go with. I'm just not sure about the RAM, with the PX845PE Pro II would the best memory for me be Corsair 3200 512 mb CL2? or would CL 2.5 work just as good? that's what I don't understand is the difference between the two of those, and I also can't figure out if the max ram that can go into this particular motherboard is 2 gigs, does this one stick of 512 (since it's DDR) count as 1024 mb? I'll list the computer that I think I want to build, and if you wouldn't mind, please tell me what you think. I'll take any suggestions because I don't wanna screw up or something.
Albatron PX845PE Pro II
$114.48 from mwave.com
CORSAIR MEMORY XMS Extreme Memory Speed Series 512MB 64MX64 PC-3200 CMX512-3200 512MB PC3200 DDR RAM - OEM 64x64 184-Pin, CAS2.5 -Unbuffered With Heat Spreader, Requires DDR Supported Motherboard - Lifetime Warranty.
$158.00
Intel(R) Pentium(R) 4 Processor (Northwood) 2.53GHz, 533MHz FSB, Socket 478 Retail
w/Fan and Heatsink, 512KB Cache, .13u (from googlegear.com with 3 year manuf. warranty)
$236.00
Western Digital 80 GB 8 MB Cache - 7200 RPM Ultra ATA/100 (from Newegg.com)
$109.00
and of course a case and a proper power suppy. Which makes me ask another question, what kind of power supply do I need to look for? Because I've read that the P4 has that extra power plug or something that some power supplies come with, you understand what I'm asking? If so, then...help please.
I'd also like it if you suggested an inexpensive yet nice looking case.
THANKYOU VERY MUCH FOR ANY HELP!
