Hi, I recently bought the albatron m/b. I am a little concerned about the temperatures I'm seeing here though. My idle system temp is running at 41c and my cpu is running at 36c. My system temps always run about 5 or 6c higher than my cpu temps which is strange in and of itself. Under load, my system temp rises to about 52c (max) and my cpu increases to about 47c. My room temps are cool so that shouldn't be a problem. Are these temps accurate and should I be worried at all?
My PC:
Intel 2.4b @ 2.7ghz (stock HSF + 1 side mounted case blow fan)
Corsair xms pc3200 @ 375DDR (aggressive timings) 2.5x multiplier
Albatron Pev PRO
Radeon 8500
I'm currently at 150fsb, however I am VERY hessitant to go any further on the fsb o/c considering the load temps above. Any advice you might have concerning my system would be VERY welcome. Thanks in advance.
My PC:
Albatron Pev PRO
Radeon 8500
