Albatron GeForce FX5600EQ Problem!!!
Pmpatel1
I had to RMA my Geforce 4 TI4400 Video Card from Albatron and they send me a New Retail GeForce FX5600EQ. The card i used while i was waiting on my new card is the ATI Rage 128 Pro Ultra. I installed the 5600EQ and when i turn on computer it makes this beep noice for like 2 seconds and nothing happens. The monitor works cause it says the Monitor menu says monitor is working, Input: Nothing. I cannot see anything. But when i put the old card it works fine. I was also thinking it could be my mobo. I have a Abit Kt7a with the updated bios, the card is a 4x/8xAGP. the mobo is 2x/4x. Anyone have any problems like this or know what i can try. I will not be able to try on another cpu till next weekend.
Link to Mobo: http://www.abit-usa.com/products/mb/products.php?categories=1&model=88
Link to Vid Card: http://www.albatron.com.tw/english/it/vga/specification.asp?pro_id=56
ThANX
hmm i had a problem with the albatron FX5600P version. it didn't work on XP!!! 🙁 :S
i couldn't find a solution either so i took the card back and demanded my money back. i hope u have more luck than me in finding how to fix it.
