Albatron GeForce 4 TI4400 HELP!!!
Pmpatel1
Hi! I had to RMA my video card, GeForce 4 TI4400, and they sent me a new one. Well, when i installed the new video card, the screen comes up blurry and fuzzy. I took it out and put my old video card and the screen was fine. I installed the drivers for the card, from www.nvidia.com, and it did not help. Anyone know what to do. Is their any new drivers for GeForce 4 TI4400, or am i doing something wrong.?? Any help is appreciated. I really want to start playing games. THANX
I also get this message after all my primary and secondary drives are loaded up, "Primary IDE Channel no 08 Conductor cable installed", but it comes up with the TI4400 and my old video card, can that be the problem? After the message windows loads up fine and windows works perfectly. its just when i have ti4400 screen is blurry and fuzzy???
HELP!!!!
HI
It could be a driver conflict. You might want to uninstall all Nvidia software and old video card software if there was any. Make sure you go into device manager and manually remove it also.
If you're running any Windows OS'es i.e. Win 9.X etc, you will need to go into safe mode and remove them there also.
Also, if you have spare computer test out this "new" Geforce 4 ti4400 on the other machine.
