I tried using this splitter for a PWM fan I have at home (still waiting for the other fans), but the fan always spins at full speed.
I can see the rpm in Speedfan, but I can't control the speed. If I connect the fan directly to the motherboard, it works fine and I can control the speed. Tried with a different PWM fan, same.
It's a simple device, so apart from some wires/connections not being ok there's probably nothing that can be broken. But sometimes one can miss the most obvious thing, so I'm wondering if there's something I could check/try.
Also, which wire(s) would be responsible for this not working?
