This one should fit. It's just a simple HSF combo. I've had the same 7500AIW in my son's computer for 5 years, and haven't any problems. How long have you had your card?
A good share of AIW 7500 cards with only HS, so I'm pretty certain it will run fine minus the fan. Its using the RV200 chip which doesn't generate a whole lot of heat. Google image AIW 7500 and you'll see plenty of fanless AIW 7500 cards.
