Hello,
Ok heres the situation. I just purchased a Athlon 64 bit 3000 Socket 939 + a MSI NEO2 (nforce 3 ultra). I previsouly had an XP 1800+ (oc'd to 2100+) and a Gigbyte Ga-7vaxp. I still have my ATI AIW 9700Pro vido card. This card worked fine in my old system but my new system it is having issues. I input the vid card, hook the power up, computer powers up for half a second then powers down. Then i have to switch the PSU on and off to reset it. Now if i disconect the power to my Vid card the computer doesnt power itself off but however it wont boot up as the power is not in the video card. I tested my ATI Radeon 9600XT in this machien to make sure it was not the mobo and it works fine. I knwo a bunch of you will say you need a better Power supply, but I got the Antec True control 550, which I knwo my self is enough, and its rated near the top PSU if not the top. My AIW 9700 Pro is running in my old Mobo and cpu with a Seagate 8MB 250 GB, 512 DDR 400 C2.5 Antec 350 Watt. It is runnin fine no issues so it is not the actuall vid card.
Now I was reading some other forms and about this issue, and one said that it is the initial draw from the powersupply that is killing it. THE AIW version initially draws a large amount, and now with the new mobo it draws even more which causes the PSU to reset it self, maybe soem kinf of serge protection. I would really liek to be able to Use my vid card in my new machien as that is why i purchased the new mobo and cpu it to get more out of my Vid card!
This is my complete specs
Athlon 64 3000 (socket939) (1.8GHZ now oc @ 2.15GHZ)
MSI K8N Neo2 Platnnum nforce3 Ultra(MS-7025)
Corsair twinx 1G 3200C2
2x 80 gig WD raid 0 not the Jumbo
1 x 80 sata (WD800JD)
True control 550 PSU (Antec)
ATI Radeeon AIW 9700 Pro
ANd it has nothing to do with my OCing my cpu as I had the same problem before I overcloacked it.
Does anyone have any solutions? Has anyone had this problem and fixed it?
Any help would be much apreciated.
Thanks in advanced.
[FNC] Jon
Thanks in advanced.
[FNC] Jon
