ScottAD
I will be building a Ryzen PC soonish, maybe this weekend. Using the NZXT Kraken X61. Should I set the rad in push-pull? If so should I mount the push fans beneath the front IO panel? There are only two vents on the front panel at the top and the bottom. I would hate to waste fans that provide poor airflow.
My thought currently is to flip my PSU upside down and vent it out of the bottom. 140mm fan for pushing air out of the back
2x1400m pushing air up and out of the top, 280mm rad on the front in push-pull if possible.
I understand every case is different just wanting to collect opinions.
