rasinhussy
Im building a PC from the ground up, got all the parts from Newegg.com.
Here's My List O' Parts:
Asus A7N8X Deluxe
Amd 2500+ "Barton"
2x256MB Corsair 2700LL
ATI 9700 (not pro)
Seagate 80GB Serial ATA
Zalman CNPS-6000cu Heatsink and 1200mm fan
Zalman ZM80A VGA Heatsink
I want it to be somewhat quiet, but have good airflow as well (doesn't everyone?)
There are 8 fans all together: (all rated under 30 dB)
2- Antec TruePower 430W (ive heard is quiet)
2- Antec Fans (came with the case, PLUSVIEW1000AMG) for rear exhaust
2- Vantec Stealth Fans for front intake
1- Coolermaster LED Fan, for side panel
1- Zalman 120mm fan for the HS
I have drawn up a Picture of fan placement and assumed airflow.
The only dead spot i can think of is the 5 1/4" Drive bay area.
My question is, is this a good airflow design in the Case.
If any body has any pointers or suggestions about different fan placement or different fans to use to make it a little quieter.
Thank You
Asus A7N8X Deluxe
Amd 2500+ "Barton"
ATI 9700 (not pro)
Thank You
