Interesting...I'm doing some different fan configuration tests, just messing around, and noticed something when getting my baselines.
I opened up Speedfan, which unfortunately only reads my CPU fan speed, to get some temps. I recorded the CPU fan speed (789 rpm) and temps with the side on. Took the side off, walked away for a half hour to let it stabilize. I returned to find (as I knew I would) lower chip temps and higher MB temp, but I wasn't ready to accept the difference in fan speed - 812rpm, a +23rpm difference between the side of the case being open or closed.
I put the side back on, and a few seconds later Speedfan registered 789rpm again. Took it off, 812rpm. This was immediately verifiable, there's no bizarre alien influence doing this.
So, fanmeisters...why?
btw - TRUE 120 + SlipStream 120mm 2100rpm on a Sunbeam Rheobus.
I'll be testing some other scenarios as well just for gits and shiggles.
-z
-z
