tranceport
Inside of you case, Is it better to have Positive Pressure, Negative Pressure, or Equal air flow.
If you had 3 fans in the back and 3 fans in the front of your case. Would you have all 6 turning at the same speeds with 3 intake and 3 exhaust? What would be your configuration of this situation.
