Mashed Potato
Step 1: cut hole in side of antec super lanboy
Step 2: cut top of cd spindle case and mount the tube over step one's hole.
Step 3: Mount fan.
This is just to get the gist of what I am thinking of. The tube would most likely cover the big typhoon but would be getting direct ambient air from the fan mounted on the outside of the case. Would this be helpful, or a waste of time? Would it screw up the airflow in the case? Is step 2 really needed, or will the fan pointing to the hsf be sufficient?
Thanks,
Mashems
Step 3: Mount fan.
Thanks,
Mashems
