Most shops, doing that type of work, are using refrigerated air dryers with .01 micron coalescing filter after the dryer. They're simple, very low maintenance and will provide about a 38f dew point. This isn't bone dry but there won't be any liquid or visible vapor.
http://www.pneumatech.com/usen/products/refrigerateddryers/ad/
If there is some reason he would need a lower dew point, a heatless desiccant unit could get it to -40f dew point Something like this, followed by a fine particulate filter, works pretty good for small operations. -
https://www.amazon.com/DeVilbiss-130500-CAMAIR-Wall-Mounted-Desiccant/dp/B000UZSJQM
To select the best type and size of dryer, I'd need to know what type compressor, (reciprocating, rotary screw, etc.,) how much flow rate in cfm, expected ambient air temperature, expected temperature of the compressed air, expected air pressure, required dew point and required level of filtration. Or, you could just wing it and start buying dryers until you stumble across one that works.
