Hi,
I have lined down pretty much all the components needed for my new tower but one thing I remain uncertain with is the cooling.
I plan on purchasing the following:
AMD X2 4200 2.2 that will be clocked to 2.40-2.50
DFI Lan Party Ultra NF4
eVGA 7800GT that will be fairly OC'd as well
OCZ 4000 VX Gold 2X1G kit
The Case i've chosen is an Antec TX1050B which comes with a decent 500W psu and has a pretty low sticker price for such a PSU.
From the Antec website i could find the following regarding Fan options:
Advanced cooling system that includes:
- 1 rear 120mm Tricool fan with 3-speed switch
- 2 front (optional) 80mm fans
- Chassis Air Guide with optional 92 mm intake fan to provide maximum CPU cooling
- Side Panel vent with optional 80mm fan to provide maximum cooling to the VGA card
Now, i don't plan on buying four more fans as i believe the noise level of 5 fans, plus the CPU/MB/GPU fans will be too much. Considering the OCZ ram will also be producing some heat at the FSB speeds I intend to run, what 2 two combination of the above mentioned fan options would be most efficient?
I was thinking going for 1X 80mm front and the 92mm Chassis Air Guide fan for CPU cooling.
What would you guys do? 2xfront? or no front and 1x92mm for cpu and 1x 80mm for GPU?
I intend to keep the Stock Heatsink that comes with the retail box of the X2 4200+, should this be upgraded first instead of the case fans?
Thank you very much for your inputs!
