I am building a new rig with this cpu. Admit I didn't do a "ton" of research as to cooling this monster. The consensus seems to be that liquid cooling is the only way to go for this guy because it's 220W and is basically just going to be like an OC'd processor in terms of heat generation. Maybe I'm old fashioned and stuck in my ways, but the concept of liquid around electronics sort of makes my hair stand up; would prefer to stay with air cooling if I can do it. I was worried about airflow in my ten year old lian li mid tower case so I got a budget case off the shelf at the local tiger direct store that has more spots for fans and a bottom mounted power supply. I bought a Cooler Master Hyper N520 fan unit but I'm not finding anyone that's saying they have that for a 9370, do you think it will be able to handle it?
That fan is a pita to install because you pretty much have to pull the motherboard to install screws on the bottom of the board, not a fan of all that so if it's a waste of my time I'd like to know now so I can abandon the idea return the beast and invest in a liquid cooler setup. (Although I'm not quite sure where I can mount the dual fans of something like a corsair n110 in this case, would probably have to pull the top fan out of there and rig a way to mount the fans there. I don't mind messing up this case it was only 60.00 no biggie).
Thoughts? Suggestions? Anyone point me to a list of cpu fans that can handle a 9370 4.4ghz? I should have the board friday for the install, if all else fails thinking I'll just put it together and use the temp monitor doodad I bought to watch the temps closely for a few days.
