Air Cooling and Power Supply
vegettoxp
Hello there Guys, I was updaing my Case and I was running to a problem with my current heatsink. I just wanted to know if I can get another heatsink that will not touch my side Panel Fan. Below you will see my current setup. Please share your recommendations on a good heatsink and at the moment, I don't plan to OC anything, I just want to have the best Air Cooling.
My new case is - Cooler Master Cosmos S (BLK)
My Current Air Cooling - Thermalright True with 120mm Fan
I am also looking to replacing my current Power Supply because I am running to wire issues. I need them to be a bit more flexable. My current Power Supply is the Corsair HX620W. Any Recommendations on this Hardware Update?
Thank You In Advance.
Sell your Tuniq 120 for like 30-40 on the for sale trade forum.
http://www.newegg.com/Product/Produc...-010-_-Product
Corsair H50 Quasi Air/Water cooling..low profile of the cooler itself..and its better cooling!
Define flexible? Literally or figuratively🙂
Do you need more power? More cables? don't like the modular?
You know I was looking at that Corsair Hydro 50, my only problem with that was Hot Air Blwoing into the case, but I talked to couple of my friends and the Coolermaster Case that I got will provide enough power to blow that hot air out. Here is what I was thinking as of my Fan setup if I were to go the route of Hydro 50
Side Fan Blowing Air In, Front Fan Blowing Air In, and Rear Fan Blwoing Fan In, but I will have Three 120mm Top Fans Blowing Hot Air Out. Good Setup?
Well I for sure need a Modular Power Supply, I just need them to be enough flexable to I can route my cable managment good. Corsair HX620W is good, but the cable are a bit stiff. It hard to move them around. I rather have selves on the cables.
