Is the power circuitry used in most just mediocre or do most Air Conditioner makers go out of their way to make sure that they use last longing (at high temps) power circuitry that suppresses >= 99.8% of input ripple, that allow delivery of high instantaneous current, and that allow good line/input regulation?
Also, do most AC makers use power supplies with active PFC, do they use passive PFC, or something else?
AC systems don't generally use DC power, so ripple is meaningless. Similarly, voltage regulation is not required for motor operation.
There are 2 main types of AC system:
1. Direct powered motors
2. Inverter drive
1.
In direct powered motors, the power supply is the grid. A switch connects grid power to the motor. Job done. The motor generally isn't affected by modest fluctuations in grid voltage, or voltage waveform problems, voltage spikes, etc.
Direct powered motors have a slightly inductive power factor (but this varies with load), as a result most AC systems include a capcitor to provide passive PFC. Active PFC is not needed for motors. Capacitors are all that are needed. They are cheap and very reliable. Active PFC is quite expensive.
When a direct powered motor starts it will take a very high instantaneous current (typically 50 - 100 A+). Because there is no power supply electronics, the grid just handles it, but you may notice the lights go dim during that instant. There are 3 problems, the voltage dip might upset inadequately designed electronics elsewhere in the building, the motor experiences a massive jerk at switch which causes excessive wear and stress, the electrical supply, wiring, etc. all get heavily stressed. Because of this, industrial AC systems in rural areas often have to install "restart prevention" or "anti-simultaneous start" systems, so that there is 5 minutes between each AC system kicking in, otherwise they risk overloading the power-company's equipment with too many current surges in too short a time (or annoying the neighbors with flickering lights).
2.
In inverter drive motors, mains AC is converted to high voltage DC, and then goes through a 3-phase inverter to power a 3 phase motor.
3 phase motors are more efficient than single phase motors, they are also smaller, quieter, cheaper and more efficient. Additionally, inverters allow precise control of motor voltage, speed, etc. This allows gentle starting, and allows motor speed and torque to be regulated to the cooling/heating requirement. This avoids cycling of the motor on and off, so more precise temperature regulation and higher efficiency as the system avoids over cooling/heating by running at full power.
The problem with inverters (and electronic power supplies in general) is they have a horrid power-factor, especially if single-phase mains supply (3-phase powered PSUs/inverters have much better power factor that rarely needs any correction at all). Single-phase inverter power factor is horrid, and as it's neither capacitative or inductive, it requires a complex correction system.
Usually this is done with passive PFC - a complex interconnection of multiple bulky, expensive inductors and capacitors. As bulk, weight and cost aren't so much of an issue as in consumer electronics. However, active PFC motor control systems are available. I don't know if any of these aPFC motor inverter systems are in HVAC; but I'm guessing if they aren't, they'll be there fairly soon, as manufacturers try to reduce the bulk of their units.
