Originally posted by: Nocturnal
When it says: Cord Option Hard wire only by a professional electrician.
What does that mean exactly? That it does not plug into a regular electrical outlet? How is it "hard wired" by an electrician?
As Heisenberg said..wired into the house wiring. If you end up having it done, put it on its own breaker 🙂
If he wants it to be portable, he can get extension cords with sufficient gauge wire.Originally posted by: Brutuskend
It carries too many Amp's to handle an extension cord.
They are quite expensive once you get down below 12 gauge though.
