- Jun 3, 2011
- 14,839
- 3,107
- 136
I got a few questions about AIOs, both in general and mine specifically.
I have a Nepton 240 that i've never been happy with. I can't put any serious voltage through it (4670k delidded w/ liquid metal), and even at stock volts it spins up the fans to loud whenever i launch a software. Also, it make NO pump noise at all, leading me to believe that i've had a broken pump from day 1, with the heat being transferred to the radiator simply through temeprature difference rather than water circulation.
question 1: does a AIO pump make noise? like, if i put my ear on the CPU block, i would hear *something*, right?
question 2: are pumps / pump blocks replaceable? Does the nepton have a pump part that can be purchased?
I mean, this thing on FrozenCPU is ranked as one of the best AIOs, and on top of that i've delidded and used the best-at-the-time TIM; i also at one point opened the delid to check if it was making contact correctly and it does - and then re-applied. So i really can't think why launching Quake Champions would make it spin, it should be hitting 50c with that workload.
Is there a way to test if my pumpo is working?
