Only difference is the print sharing, otherwise identical...
you question as to wether or not you need print sharing . . . . well, it is nice to not have to send the file.... but it is also more $$$ so if you don't mind the little x-tra $ for that then I would go with it...
-Ryan
<< Related question:
I am looking to purchase a router, any preference for the DL-704 as compared to the DL-704P ............. ?
Do I need the printer sharing function .............. if several pc's are networked, can't I just send the file to the pc that's hooked to the printer and print from there ......... are there other advantages to the DL-704P?
Are these routers equal otherwise, or am I giving up features to gain the printer sharing?
Thank's for the info................ >>
