Uninstall it and reinstall it, sounds like your software is screwed up. You may want to download it again, if you install it again with the same software you originally did, you will get the same results.
Maybe try uninstalling, then going through your registry and deleting all traces of it, then reinstalling. If this doesn't work then you've got me stumped.
