AHHH!! HELP ME WITH IE 6!!
Eminem2k1
688
Sup guys i got IE 6 but there is something that annoys me alot! A runtime error has occured, do you wish to debug? this happens at diffrent sites including Microsoft.com, also in the Microsoft Intellipoint & Natrual Keyboard Demos that show you how to set up the items. When i disable Debugging in Advance options i get "An error has occurred in the script on this page" "do you want to continue running scripts on this page" instead...i have tried clearing out the cache 2 diffrent ways through ie & a utility called IE Washer, pleace help!
I am running
Win2k W/ sp2 and all updates
364 ram
800 T-bird
Zim Hosein
Super Moderator | Elite Member
65,308
403
Eminem2k1, since you have already cleared you cache, try going to the add/remove list in the control panel and then select IE from the list. It should give you the option to "repair" IE, reboot and see if it helps.
epa80
20
I had this same issue. Something I tried that seemed to work, was to go into Internet options, then advance, then select restore defaults. It's a pain because then you have to make your changes all over again, but, it worked for me.
-Ed
epa80@home.com
