ahh need ap physics c help :(
Wheatmaster
i keep trying but i get the wrong answer:
A satellite of mass 300 kg is in a circular orbit around the Earth at an altitude equal to the Earth's mean radius. Find (a) the satellite's orbital speed, (b) the period of its revolution, and (c) the gravitational force acting on it.
a. (mv^2/r)=GmM/d^2 v=sqrt((6.67x10^-11)(5.98x10^24)/(6.37x10^6)=7.9x10^3m/s
answer is 5.59x10^3m/s?
It's going really, really fast and weighs a whole lotta frickin' tons and stuffz. Really. Like one BEEELIION...stuffz.
Originally posted by: Tweak155
use 2x the radius because it that is the distance it is from the center of the earth
whoa thats right but why is it 2x the radius? i don't understand. isn't the center of the satellite to teh center of the earth the radius of the earth?
No, because the distance from the surface of the earth to the satellite is the same as the radius of the earth. Therefore, from the center to the surface of the earth is one radii, from the surface to the satellite is another radii. So try 2R.
oooo i read it wrong 🙁 dohhh
ok for b.
i'm trying: 2(pi)r=vT
2(pi)r=(5.59x10^3)T
ok for b.
2(pi)r=(5.59x10^3)T
isnt period just 2(pi)r?
er wait, no you have it right, you are getting the wrong answer?
ok for b.
2(pi)r=(5.59x10^3)T
nm i got it. for c, is the formula just mv^2/r?
ok for b.
2(pi)r=(5.59x10^3)T
It should be something with 2 masses in it, not just one, i totally forget the formula but you need the gravitational constant in it
