- Dec 25, 2007
- 1,243
- 3
- 76
Hello,
With the price of WD's 640GB drives falling again, I'm really tempted to get one. I'm currently using 3x5000AAKS drives and they're fine, but new drives are just so cheap now.. I wouldn't mind having one more.
That said, my P182 is almost filled to the brim with hard drives as it is, so I want to look at external options. I currently have a 1-drive IDE external enclosure I'm going to sell shortly, but it's quite difficult to get at. I'll post later for enclosure recommendations after doing a bit of research on it, but my main concern right now is hot swapping.
I'd prefer my new one to have 2 bays and support hot swapping. Internal SATA drives also support hot swapping, but require AHCI to be installed/enabled. I do not have this currently.. All my SATA drives are running in IDE mode, and sites seem to recommend against switching over to AHCI mode once I've set up on IDE.
Without having AHCI enabled, will this affect the ability of any external enclosures (and associated SATA drives) and their hot swapping? Will I flat out not be able to hot swap them at all?
Thanks in advance.
Thanks in advance.
