- Nov 24, 2008
- 71
- 0
- 0
I recently bought an Intel X-25M 80GB (G2) SSD and a copy of Windows 7 Ulitmate OEM.
I installed Windows 7 successfully on the SSD, however, it's currently set to IDE in BIOS (I didn't figure out that it needed to be set to AHCI prior to install).
I've done some research online and found a solution in a changing a registry value, rebooting, going into BIOS and changing IDE to AHCI.
I tried this and the system will not boot or allow me into bios. It get stuck at the Marvell Adapter screen. The only way for me to fix this is to reseat the CMOS battery and ensure that BIOS is set to IDE.
I'm new to this whole SSD setup thing, so I'm at a complete loss as to what to do.
Does it really make that big of a difference between IDE and AHCI for my SSD? (From what I read so far, the answer seems to be a yes.)
I am not sure if I am making the right changes in BIOS. I also read that I should be installing Intel AHCI drivers.. no idea how to do this or if it needed.
I'm also thinking that something with the Marvel Adapter is conflicting/getting screwy when I change the setting to AHCI.
Any help would be greatly appreciated.
