- Nov 25, 2012
- 12,086
- 2,774
- 136
So, corrosion strikes yet again on my mom's Toyota Matrix and today, I decide to give the positive terminal prolonged drenchings in baking soda to really get every last bit of sulphuric acid out, and when finished, it is clear that whatever lead was on the terminal is pretty much gone and the copper is all exposed now.
Another random thought. It seems that Toyota designed the terminals with knowledge that the postive battery terminal corrosion happens, since the positive terminal is easy to detach with a little 12mm bolt while the negative terminal is crimped.
Random thought #2. Before today, like a couple weeks ago, I took a look at the yellow terminal cleaning spray while browsing through Home Depot. It's main ingredient is sodium bicarbonate, aka baking soda.
I have ordered some allegedly gold-plated terminals for $3.60. We'll see how the gold stands up. Although, the fumes of acid will slip through the air gaps and attack the lead posts on the battery anyway. Hmm. I need to get some terminal protectors stuff to fill in the gaps.
