AGP pro slot??? Help please
nealh
7,078
What exactly is this? what video card will require this type of AGP slot?
I am ordering an Abit K7tA that does not have this should I cancel the order and go with the Asus Av7M that does??
Thanks
Neal
sitka
895
Diamond Fire Gl3 uses AGP pro. (thousnads of dollars) There just aren't that many cards out there now that use it. What it allows is more voltage to be supplied to the card. If a bunch of GPU's get built that need more power then the cards could be built to utilize the Pro specification.
