AGP/PCI lock
brazzmunk
187
Is it ok to set the lock at that on A8V Delux???
Would there still be a lock when 75.4/37.7 is selected
i have problems with AGP bus locking up above HTT 280 and this was one of the suggestions... The thing i concerned the most is HD corruption as it happaned before.. i have 4 UDMA 66 Seagate barracuda's
VirtualLarry
56,587
10,227
If you are suggesting to run your AGP port at 75.4Mhz, and your PCI bus at 37.7MHz, those are definately way out of spec, and the PCI bus one will likely be the more severe problem of the two. It could easily cause IDE HD data-corruption issues at that speed, if the IDE ports' clocks are based on the PCI clocks, and many are.
brazzmunk
187
well i set it back to 66/33, the thing is alot of people are having issues with early RADEONS having VPU recovery issues playing games with HTT over 260 in my case over 278, one of resolutions were to set lock higher... guess that's not a choice for me
obeseotron
In my experience 10% over spec is about the limit for HDD's before corruption starts, AGP is much more dependant on the card. I had an old Geforce that would do a 100Mhz AGP bus, newer ones are much pickier. Try a verly low HTT multiplier also. Anything above 600Mhz total will not increase performance, try 3x or even 2.5x.
bjc112
11,460
75 is border line..
I have experience some issues with MAxtor HDDs @ 75.. However some drives take it better than others..
I would agree with the 10% mark as good starting point.
