Agh! Kink! Help!
SagaLore
24,036
21
Two days ago I woke up with a kink in my neck. Doesn't really hurt, its just uncomfortable. I don't recall waking up in any odd positions. I've had several people try to pull on my head so it would pop, but no luck. I tried drinking lots of booze to relax my neck so it would pop on its own, but no luck. :( Will someone come over and help me crack this out?
cliffs:
- I'm kinky
- please pull on my head so I will pop
- will trade services for free booze
Actually, if you could recommend any stretches or yoga moves to get my neck straight again, I'd appreciate it.
2Xtreme21
7,044
Take some ibuprofin (though not with booze in your stomach) and go to sleep on a flat surface. Don't use your pillow and lie on your back. That helps 99% of the time for me... even when I wake up with a bad one. 10 more minutes of sleep is all it takes to kill it.
SagaLore
24,036
21
Hmm... does it have to be ibuprofin? I've tried it before for various ailments and it seems to have no affect on me. I have Tylenol and Aspirin (my Aleve is at work).
SmoochyTX
13,615
I hate it when I get kinks. I just try to work them out the best I can.
2Xtreme21
7,044
I use ibuprofin because I find it's more of a muscle relaxer.
Edit: Anti-inflamatory is what I mean.
SagaLore
24,036
21
Originally posted by: nakedfrog
This thread COMPLETELY failed to deliver what I was expecting.
This thread is an investment. Contribute, and you shall reap the benefits! ;)
nakedfrog
63,307
19,689
If you'll deliver the kink... I suggest soaking in a hot bath with epsom salts. They're pretty cheap and easily available.
NoShangriLa
1,652
See doctor/chiropractor/massage therapist. Or get a rub down with a555/bengay/deep cold & take ibuprofen with lots of water.
