Age old question: Gas or Charcoal?
iamme
21,058
What should I buy? I'm leaning towards charcoal because it's cheaper, and lighting something on fire just feels more like barbecuing. However, gas is so convenient and fast.
Whatcha guys think?
Jerboy
Banned
Oct 27, 2001
5,190
Whatcha guys think?
Charcoal grill cooks better tasting food, but get the gas. Charcoal grill often ends up underused because they're inconvenient.
iamme
21,058
You can't use wood chips and smoke food in a gas grill, can you?
UltraQuiet
Banned
Sep 22, 2001
5,755
I have both. I use the gas grill for things like burgers, dogs, steaks, chicken breasts, fairly quick stuff. I have a charcoal smoker that I use for ribs, Boston butt (not you Baff), brisket etc. It just all depends on what I'm cooking and how much time I have but I've found it convenient to have both.
Dave
ObiDon
3,435
Mmmm...carcinogens...(charcoal) ;)
Actually, I saw a product in a pouch or something that you could use with a gas grill to "smoke" food. I don't remember what it was called though.
That being said...Fire! Fire! Fire! Nothing beats burning something that is trying to resist!
Czar
Gas: Easy to use, quick to heat up.
Charcoal: Food tastes alot better, get to play with fire :)
djheater
14,637
You can use water soaked wood chips double wrapped in an aluminum foil pouch with holes poked in it to smoke a gas grill but it seems silly... there's no advantage I can see to gas... It takes all the fun out of it....
jamison
2,326
It isn't an "age old question" when it comes to the taste and quality of the food, get charcoal.
Moonbeam
74,736
6,759
I use charcoal but mainly because that's what I have. The burning fat will smoke your food in either case from what I've read. Were I interested in a new one, I'd get gas or at least one that could use gas even if only to start the coal. Don't know if they make dual use ones though. As to the question of health, there are toxics that form in smoke and coat your meat as well as nitros amines that form from charring. I find them both delicious.
ObiDon
3,435
Is grilling food over charcoals bad for you?
I recall seeing something on TV (20/20?) where they said that the fat dripping onto the charcoal and burning off caused carcinogens in the black crusty stuff that forms on your food. I don't remember any numbers or anything and I don't know if this has since been invalidated by further research. Just something to think about/search for.
Personally I don't worry about it. There's so many other things out there that cause cancer (probably even breathing) that it's pointless to be overly paranoid about it...just enjoy your food. ;)
Vette73
21,503
9
Gas is good afetr the grill has some miles on it. I use gas as it is quick and easy. Charcoal adds more taste depending on the charcoal and grill you have, but is a mess and not as easy to use if you want to do something small. I got a small gas grill as I just turn it on, cook, turn it off and I am done, no major cleaning.
But for a LARGE party or special event I would look for charcoal.
Scipionix
1,408
Bottom line: are you going to get the charcoal grill going just so you can have a burger for lunch?
That reminds me...
N8Magic
11,624
Gas grill.
You can't beat the convienience, and I find charcoal grills to be to uneven in their distribution of heat. I'm a steak connisseur and I can't seem to get a charcoal grill hot enough to cook the steak as I like.
ObiDon
3,435
Can I vote George Foreman grill? :D
Foreman grill rocks! If it'll fit in there, I try to cook it in there...chicken, sausages, hash browns, corn dogs, and so on. Corn dogs come out awesome! Okay, okay, I'll go now... ;)
iamme
21,058
Originally posted by: LordMaul
Originally posted by: djheater
Lump charcoal... not briquets....
what is lump charcoal?
Found the answer to my own question:
Advantages of "lump" Charcoal
* Lump charcoal is an all-natural, 100 percent hardwood product with no additives.
* Natural charcoal heats faster than briquettes, so food can be cooked over natural charcoal within 5 to 7 minutes after lighting.
* Lump charcoal can be lit sans lighter fluid and with just a match and some newspaper which means no off-flavors.
* One pound of hardwood charcoal produces the equivalent heat of two pounds of briquette charcoal.
Disadvantages of "lump" Charcoal
* Consumer demand is limited.
*Current price is nearly twice that of briquettes.
*Lump charcoal is bulkier, has odd shapes, and crushes more easily.
* It tends to become dusty and flakes-off.
