Aftermarket Cooling Solution for AMD R9 290
rip
613
I got a great deal on an R9 290 reference card. As you probably know it sounds like a jet plane when the gaming (Witcher III) gets going. I'm wondering if anyone has found a fairly simple but effective aftermarket cooling solution for the R9 290. thanks,
Dana
Killrose
6,230
8
Another thing to consider is your Power supply internal fan spooling up and causing noise. Before I installed my Zalman VF3000a cooler, I noticed using R9 290 fan monitoring that my computer was still noisey AFTER the 290 fan speed dropped. Turned out my PSU fan was over worked trying to cool itself due to the power requirements of the 290. I was putting all the blame for fan noise on the 290 reference blower when in reality quite a bit of it was due to the PSU fan.
